Auto A/C Compressor Power Requirement?
First of all - hello to everyone! I am not an engineer, rather a professional autobody painter that has a great interest in custom a/c systems and stumbled upon this thread -thread108-138387: A/C Compressor efficiency...?
I had a question I was hoping someone hear could answer. Suppose I took the whole a/c system out of a 2003 for crown victoria and wanted to drive the compressor with a briggs and stratton type small engine - how large of an engine would it realistically take to turn the scroll type compressor from the crown vic with a full load on it?
Hopefully someone here has a thought on this.
              Mike
RE: Auto A/C Compressor Power Requirement?
8 hp at 6000 rpm. If you don't like that gear it up.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Now, when you state 8 hp at 6000 rpm -  is that 6000 compressor rpm or engine rpm?
If the compressor where to be ran at a constant speed, what would that rpm be?
Thanks for the fast reply!
Mike
6000 compressor rpm. Half that at 3000 rpm, and so on.
Cheers
Greg Locock
