Restrained Basement Wall Design
I know a lot of questions have been posted on this topic, but I still am unable to see a popular consensus:
I have a very long rectangular building with a full basement (10' ceiling). There are no intermediate walls perpendicular to the long direction. The floor trusses run parallel to the long dimension of the building, with steel beams spaced at about 25' o.c.
Since the basement is backfilled on all sides, I would like to design the walls as restrained masonry walls, and the contractor would obviously like to avoid the extra expense of a cantilevered wall. The geo report specifies the at-rest pressure as 63 pcf, which gives a lateral reaction of roughly 1000 plf into the floor sheathing.
I cannot justify the load transfer at an interior sheathing panel joint. I am able to justify the load transfer through the bearing plate/ledger into the sheathing via blocking, but that's where I run into problems. The APA recommends a 1/8" gap between sheathing panels, which means that 1000 plf will have to be transferred across this joint by the sheathing nails/screws. I am also slightly concerned about plywood buckling under axial load, since the tabulated values in the NDS assume all edges are restrained, whereas in my case the floor trusses are spaced at 24" o.c.
I have seen many designs where a 10' basement wall is designed as a restrained wall, and many engineers extend blocking several truss bays to get the load into the sheathing, using the IBC diaphragm shear values - which is not correct - this is not a diaphragm, rather an axially loaded plywood floor. Nevertheless, this design has been employed on many local projects (Phoenix, AZ), and seemingly without problems.
Any suggestions on how to justify this? I would like to avoid putting blocking in all the way across the building, as this is not a realistic solution when shrinkage and workmanship are taken into account.
RE: Restrained Basement Wall Design
But I don't agree fully with the description that the plywood is an axially loaded "member". If you simply run blocking perpendicular to the exterior wall and extend it far enough so that the plywood-to-blocking nailing is adequate for the transfer of the top-of-wall lateral thrust, then you are OK for strength. The blocking can be spaced at close enough intervals to keep the length of the blocking to a reasonable amount.
You can have fewer lines of blocking, but the blocking would have to be longer.
You are then simply trying to create a case where the diaphragm is receiving load similar to the case where the joists are perpendicular to the wall.
You must also check for stiffness of the diaphragm as well.
Personally, I would go with the cantilever wall - it would make all your other concerns with respect to the plywood floor "diaphragm" go bye-bye. However, I would use CIP concrete, not masonry block.
Mike McCann
MMC Engineering
Mike,
63 psf equivalent hydraulic pressure is what you would expect for at rest pressure with no water involved. If there is water, it would be higher, and then you would have to consider uplift.
AZeng,
If you want to persist with the floor bracing the wall and don't want to use a concrete floor, I would not rely on the plywood for axial loading. I would decrease the beam spacings so they act as combined bending/compression members, with the top of the wall designed to span horizontally between the beams. And there is nothing wrong with doing the walls in reinforced concrete masonry. Remember the waterproofing on the outside.
To me, pressures that high means that the soil could be more porus, lowering the intergranular friction and allowing the water to infiltrate more quickly. I'd check it out.
Mike McCann
MMC Engineering
If you are still uncomfortable with that, you could design the diaphragm to span 25' between beams, and design the beams for the axial force. You would have two diaphragms in each 25' span, one taking the lateral pressure on one side, and the other taking the lateral pressure on the other side.
DaveAtkins
"But I don't agree fully with the description that the plywood is an axially loaded "member". If you simply run blocking perpendicular to the exterior wall and extend it far enough so that the plywood-to-blocking nailing is adequate for the transfer of the top-of-wall lateral thrust, then you are OK for strength. The blocking can be spaced at close enough intervals to keep the length of the blocking to a reasonable amount."
JAE, how is this not an axially loaded member? If you take a section of the floor at the middle of the building, your FBD will have 1000 plf on both sides (see attachment). As I stated, I have already designed the blocking so that the lateral thrust is adequately transfered into the sheathing. But as Hokie stated, this is NOT a diaphragm!
Imagine if this were a tunnel, and not a house, so there were no shear walls. The structure will still work because the two retaining walls are still resisting each other's lateral force via the floor, which is indeed an axially loaded "member". If the plywood was replaced by a series of steel pipes, I think you would agree that these were axially loaded members (i.e. what you would use in a braced excavation). There is no difference here - the plywood is a continuous wall brace. Calling the floor a "diaphragm" in this case, and analyzing it as such is eroneous - there is no shear transfer, just axial load.
In regards to spanning diaphragms between the steel beams - I had considered this, but I don't think it's a good idea. First, you will have a ton of horizontal reinforcing at the top of the wall (and I'm not sure you could even get a horizontal span of 25' in a 12" masonry wall). Second, it will be difficult to design a connection for a masonry wall that will adequately resist 25k lateral load. It might be done, but to me it just looks like a bad idea from the outset. Third, since this is such a long building, it will need control joints in the masonry wall, and I intend to put them between each steel beam. Obviously this will be problematic if I'm using the steel beams as compression struts and spanning the masonry horizontally.
Dave, how would you obtain the capacity for the nails? I am guessing that 10d nails at 2" o.c. will be in the right ballpark.
DaveAtkins
I would think that the bracing force will be far less than the gravity loads that the trusses will be designed for (20D + 40L). I think the plywood would buckle between the trusses before any sort of truss failure occured. Plus, the plywood will be 7/8" thick, 24/48 span rating.
The contractor owns a masonry company, so is pressing hard not to use concrete (I already suggested to use concrete but he was not impressed!) Another option I was think of is using two layers of plywood and staggering the joints. This would decrease the load in each of the two layers of plywood and would reduce the load at the panel joint to a sufficient level. Thoughts?
What hokie said:
"If you want to persist with the floor bracing the wall and don't want to use a concrete floor, I would not rely on the plywood for axial loading. I would decrease the beam spacings so they act as combined bending/compression members, with the top of the wall designed to span horizontally between the beams. And there is nothing wrong with doing the walls in reinforced concrete masonry."
is correct in my view. You can try to get a wider bond beam at the top of the wall, heavily reinforced, to span the 25 feet between steel beams, or you can cap the top of the masonry wall off with a concrete beam which could be cast such that its inside face is on plane with the inside face of the masonry wall below, and its outside face extends into the dirt beyond the outside face of the masonry wall below.
Thus you have sort of a concrete beam laid sideways reinforced to span the 25 feet and take all the lateral earth load into the steel beams which can easily be designed to take the axial load to the other side.
You'd satisfy the builder by using masonry walls and yet still use concrete to span.
1. Full basement (e.g. no unbalanced dirt forces)
2. Fully blocked diaphragm
3. Dimension lumber joists that have face mounted hangers on a ledger board
4. Dimension lumber blocking perpendicular to joists spaced 1'o.c. for 1st joist space, 2' o.c. for next joist space, and then the 4' o.c. for the blocked diaphragm thereafter.
5. Added nailing into the joists or blocking rows to justify the 1/3 overall dirt force load path into the sheathing. I visualize this like a drag strut/collector loaded in reverse...
I cannot recall for sure, but I think APA might have some guidance about compression loading; I know they have some good stuff for tension loading. With wood floor trusses spanning the long dimension, however, you are not getting any "help" axially from the trusses like my dimensional lumber scheme which is a more "residential" concept; 36' x 150' is a commercial building structurally if not per the occupancy category.
There are thousands of houses with a full basement performing just fine with the load path being some BS toenails through the joists into the sole plate with BS 1/2" anchor bolts at 4' o.c. There is really no load path parallel to the joists... I have fixed a few such full basement houses with helical pier tiebacks too, but 99.9% of these work in practice, if not numerically. This kind of "reality vs. calculation" issue makes me wonder if what we do as SE's makes any sense, sometimes.
If you are (justifiably) nervous about this load path for large permanent lateral forces through a wood diaphragm (not temporary seismic or wind that may not even occur), given the AZ statute of repose for PE liability = infinity, then I would simply pour a concrete floor with steel beams. This is probably more "value received" to the building owner than a cantilever CMU retaining wall (stiffer stronger quieter floor system with less structural depth). Mechanical and plumbing might be more problematic with such a framing scheme though.
Also, 63 psf is a pretty high "at rest" EFP lateral earth pressure; this would reflect a fairly active clay in my locality. When given high numbers like this, I have sometimes asked the geotechnical engineer for a lower "at rest" value for a sand backfill zone to reduce the lateral earth force on the structure.
