bonding tubes
bonding tubes
We are building a carbon fire frame for a wheelchair for a customer. The mould is a rather complicated one, consisting of 14 individual moulds. The idea was to laminate the two halves of the tubing and then bond them together.
What should be the best way to bond the two halves of the tubing (in respect of adhesive and method we should use)? The wall thickness is 3mm.
George
George
RE: bonding tubes
You do not say what diameter your tubes are.
On a tube over about 2" in diameter you could use a stepped lap joint with a tape over the outside for security.
If the tubes are smaller than that, I would not suggest making them in two halves. Use one piece tubing and a tape wrapped finger joint.
The tapes should be woven carbon or glass.
B.E.
RE: bonding tubes
The tube O/D is 1"
George
RE: bonding tubes
You might want to study 'filament winding' and 'tape winding'. Simpler tooling, stronger tubes.
You'd still need moulds for the lugs to join the corners.
Mike Halloran
Pembroke Pines, FL, USA
