"TRUE LENGTH" call out
Is there a standard (or abreviation), to explicitly state that a dimension is the true length?
Scenario: I have a bent tube, with bends in more than one plane, ie compound bends. I have my main views showing the entire tube, but my auxiliary views, which show certain sections of tube in their true view, are only partial, to save space. I want to make sure the vendor knows that the length in that view is the true length. It should be obvious from the direction the view is taken, but not knowing the vendor, I't like to "idiot proof" things as much as possible. I'd also like to do this via some standard, if one exists, for the same reason.
Is there such a standard, or accepted practice? or should I just add the comment "true length" to the dimension?
Dave
Dave
-Dave
Everything should be designed as simple as possible, but not simpler.
RE: "TRUE LENGTH" call out
You can show one view with isometric indicating all dimensions
Or...
You would show your normal views. Additional views would indicate if rotated (CW 45 deg, CCW 30 deg, etc) from a view.
More info: http:
Or...
Show an Iso view and include a bend table (X,Y,Z) coordinates.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Jul 02, 2008)
-Dave
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the be
Believe it if you need it or leave it if you dare. - Robert Hunter
Thanks for the input.
-Dave
-Dave
