reload sheet format
reload sheet format
We have recently changed the title blocks but we would like to use some of the old design and drawings. I wrote a macro that replace the old sheet format with the new one and it works quite nicely except it doesn't update the drawing. After running the macro the user has to go to sheet properties and hit "reload the sheet format" button. How do I eliminate this step and reload the sheet format from the macro? I couldn't find any indication in SW API help. I'm using SW 2001 Plus SP2.
Andrew
Andrew
RE: reload sheet format
Try to use Ctrl + Q.
It can helps.
Maybe if you setup the macro this way it will work for you.
Crashj 'one can only hope' Johnson
