PED Code Filler Metals
Hello everyone,
I design pressure vessels to ASME Section VIII Div 1 code. I'm currently waiting for a design to be approved for European installation.
This is the first time I have dealt with PED code.
I've got to write a WPS for the PED inspector to witness, and the problem I'm having is that I can't find a manufacturer of filler metals that can provide a Certificate of Compliance with the necessary lot/batch/heat numbers and stating that they were manufactured to the EN code.
I'm in a hurry with this because it was an oversight on our engineering teams part.
When I question a manufacturer about the C of C, they usually reply, "Never heard of it."
Can anyone tell me what manufacturer, that would have it in stock, I can get the appropriate filler metals and documentation from?
Thanks in advance.
RE: PED Code Filler Metals
Try getting some European product such as Metrode or Smitweld (Available from Euroweld), Bohler-Thyssen, Sandvik, or ESAB.  Regardless of whether they carry any or not, the Euroweld folk are pretty knowledgable and may be able to help you.
Here is a link to Guideline 7/10 to the PED regarding welding consumables. They do not have to be manufactured or certified to any EN standard, the level of traceability has to meet the EN standard. I have qualified procedure in the US for two different (German based) notified bodies and both allowed US welding consumables with ASME/AWS certification and marking.
http://ec.europa.eu/enterprise/pressure_equipment/ped/guidelines/guideline7-10_en.html
