Problem of transfering values from URDFIL to UTEMP
Hi
I am making this model where i am calling some variables (void ratio, pore pressure, etc) and creating others (Bf) using UVARM subroutine. variables are read using URDFIL, then by using common block to transfere the values to UTEMP where i am relating the TEMP to (Bf).
The problem is , although abaqus reads the whole Bf array in URDFIL subroutine, but yet when it is transfered to UTEMP subroutine it only reads the last value of Bf which makes TEMP= a constant value in all nodes. Anybody can guide me how to overcome that and make UTEMP reads all Bf values?
   SUBROUTINE UTEMP(TEMP,NSECPT, KSTEP,KINC, TIME,NODE, COORDS)
C
      INCLUDE 'ABA_PARAM.INC'
C
      DIMENSION TEMP(NSECPT) ,COORDS(3) ,TIME(2)
 REAL    Bf(20)
 COMMON /TEMP/Bf
 write (7,*) 'Bf =', Bf(1), 'UTEMP'
 TEMP=Bf(1)
      RETURN
      END
      SUBROUTINE URDFIL(LSTOP, LOVRWRT,KSTEP, KINC,DTIME, TIME)
C
C
      DIMENSION ARRAY(513),JRRAY( NPRECD,513) ,TIME(2)
      EQUIVALENCE (ARRAY(1),JRRAY( 1,1))
 REAL    Bf(20)
 COMMON /TEMP/Bf
C
C FIND CURRENT INCREMENT.
C
 CALL POSFIL(KSTEP, KINC,ARRAY, JRCD)
      DO K1=1,999999
         CALL DBFILE(0,ARRAY, JRCD)
         IF (JRCD .NE. 0) GO TO 110
         KEY=JRRAY(1, 2)
C
C RECORD
C
      IF (KEY .EQ. 87) THEN
 Bf(1)=ARRAY( 6)
 write (7,*) 'Bf2 =', Bf(1), 'URDFIL'
 END IF
 enddo
 110  continue
C
      RETURN
      END
RE: Problem of transfering values from URDFIL to UTEMP
Did you declare Bf in a COMMOM block in the main part of the subroutine file (i.e. before the first SUBROUTINE) ?
