how to find intake leak
I seem to have an intake leak upstream of the throttle, and I'm looking for suggestions at to how I might find it. The vehicle is a 2005 scion xb.
I first suspected that I might have a leak when I started hearing a "squealing" noise that was throttle dependent - no noise at idle, and no noise at ~10% load, but at very slight openings there is a whistle/squeal which has only recently become noticeable (but is annoying). I did a pretty quick visual inspection of the intake system and didn't find anything obvious... I decided that if there was a leak it must be a small one, so no big deal (except that damn squealing).
I've just gotten back the results of an oil analysis, and (surprise, suprise) it shows high silica and various wear-related metals. Seems like my engine is getting dusted. Now I need to find that leak.
When I'm under the hood with the engine running, the leak is not loud enough for me to get a bead on it even if I monkey around with the throttle. It doesn't help any that I've got some halfway-bad alternator bearings joining the chorus (I'll replace that when it stops charging).
RE: how to find intake leak
You might even get better gas mileage ! ( OK - it's a joke - just thought I'd start that whole discussion again... )
The classic check is to have the engine running and spray a little carb cleaner around suspect areas. The rpm will go up if you have a leak.
Do it at your own risk - carb cleaner is very flammable.
I thought about the ol' spray cleaner trick... while that approach seems to work fine with relatively small areas (gasket interfaces, for example), in this case I'm talking about a few feet of convoluted plastic crap, and I'm a bit worried about both fire and inhalation.
Any other suggestions?
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
So, find a smoker and use their talent, or find a smoke machine.
Franz
Rod
No good alterate explanation for the dusted oil... will have to have another analysis done in a few k-miles to see if the problem persists.
There is a resonance in the manifold at idle or just off-idle that sounds remarkably like a vacuum leak. They all do it.
A "false air" situation (upstream of throttle) never makes a whistling noise.
Hope that helps.
How many engineers does it take to find a pinhole in 2 feet of tubing.....
Oh yeah, that may not fix the problem??? Love engines, just love 'em.
Rod
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Just for giggles, Isaac...I once had an odd scratching sound in my '61 Vette...My cat got 'lost'...we found him behind the passenger side kick panel!
Rod
