Anti-dive w/ strut?
Anti-dive w/ strut?
Guys-
I think I know the answer, but am looking for confirmation. On a typical strut front sspension (MacPherson), is there a possibility for anti-dive characteristics (under braking)?
Bill
Bill
RE: Anti-dive w/ strut?
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Bill
Bill
Norm
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
"If you raise the height of the rear pivot of the front lower control arm you will reduce the amount of dive under brakes and reduce the amount of lift in the front end when accelerating"
How does it do both anti-dive and anti-lift with the same change? Especially with AWD/FWD configuration, I was of the understanding that you gained one and lost the other.
Hopefully someone will dive in here if I'm wrong, but my understanding of the theory is the IC when viewed from the side will move forward and up, closer to the Cog height which will reduce the loading and unloading of the front, to in turn reduce dive under brakes and reduce the lift on acceleration.
Dave
The anti effect is consistent with the direction in which the acceleration is being considered, not a "see-saw" kind of thing where the effect associated with one acceleration direction are traded off against the effect for the other. This does not necessarily imply that the effects are equal, accel vs decel.
Norm
Cheers
Greg Locock
I know you have directed your question at Greg and I hope he replies but the ALK (Anti Lift Kit supplied by a number of manufacturers) for the Subaru's are not described accurately by them. The ALK in fact counteracts the anti lift and anti dive that is built in to the cars.
So the kits actually increase lift and dive. Which IMHO is a bit of a smoke and mirrors sell to people. It reduces the understeer in the front on corner exit where the street driver feels an issue with the set up of Subaru's but in fact a well set up car will not benefit from the kits.
Dave
In what way do you mean 'benefit'? Antidive and antisquat aren't good things in themselves, you add them to get specific outcomes.
Cheers
Greg Locock
The standard Subaru cars have a strong tendency to understeer, it depends on which car you start with but the road going WRX is unmanageable and the competition spec base cars from Subaru are not as bad and every specification in between is a gradual improvement.
With better diffs, good dampers and good spring rates you can get the cars to be reasonably close to neutral in balance throughout the corner.
We tested the ALK's on a well sorted Subaru tarmac rally car. In practice we found the effect to be the same/similar to reducing spring rates. We had less traction in a straight line on starts and on the tighter turns. The car tended to pitch over the front outside wheel into corners and we had an increase in bump steer.
Dave
For mainly tarmac events starting with a 95 WRX, I was going to be:
increasing spring and ARB rates
improving dampers (ideally independent adjustment of bump and rebound)
Adjustable (lengthen) lower rear arms
Widen front track (later model)
Move strut tops inboard for more camber gain with bump travel
More front caster
Lower the car but also regain some roll centre height back (front and rear)
Reduce bushing compliance in suspension and subframe mounting
Improve all three diffs (suretrac, DCCD, plated)
Increase chassis stiffness with braces (not just typical strut tops bars)
remove some weight from the car (preferable front)
I would also like to improve the geometry of the rear strut to reduce some of the angle (when viewed from the side) but this will be pretty major surgery and more likely involve making new rear hubs.
Have I missed anything? Any of these a bad idea?
If you think about what an anti does, it promotes an increase in transient weight transfer during a manouevre.
That can be good or bad, but sooner or later there will be a corresponding decrease in weight transfer as the body levels out. You don't get something for nothing. If you can phase those two effects to provide an increase in overall performance, great. But by themselves there is no 'average' benefit and a simple analysis says that on average they should cost you grip.
As to the rest of your suggestions, you don't mention tires, brakes or aero, which is where I'd be starting (maybe not aero depending on speed). So I'll take those as read.
I've never thought about rally cars here's my comments
why, are you running out of travel?
OK
For more static camber?
OK
OK
More front caster
why? Some sort of fake Ackerman?
OK, but what you gain in ultimate grip you'll trade off against higher spring rates, but may gain back in less ARB.
OK
Definitely
Hard to do but yes.
Hard to do but yes.
That is a lot of work, why not buy a better car (seriously)?
Cheers
Greg Locock
Aiming to lower the car to also lower the COG, then to correct the roll centre change this gives I aim to raise the roll centres back slightly, more for better geometry than anything else (get some outside wheel camber gain will roll rather than loose it) . Lower the car will also reduce bump travel hence firmer springs, also firmer springs and ARB to increase roll stiffness again more for keeping good geometry and contact patch through corners and therefore not needing so much static camber (static camber generally only reduces straight line braking capability - as I understand?)
Extra front castor - ackerman?? I understand ackerman but I am thinking the increase in caster will help the camber with steering lock so again, less static camber needed, am I right or missed the point?
Ackerman I am pretty stuck with, as the front hubs will stay and the rack position is difficult to change, although I do intend on making a new crossmember as some point so I will keep this in mind.
Buy a better car??
To buy a better car would require a substantial bigger dollar outlay in the beginning which I don't have (otherwise I would be asking how to make a Porsche GT3 go better or buy an F3) hence I can have something that has 4 doors and can get me a short trip to work (bad public transport) and can give me satisfaction building and improving it for car club level racing, I have no plans (or probably enough skill) to make a career out of it.
This car has cost me $7k and buy the time I am done will possibly spend another $20-30k with modifications, so for the similar price of a current model WRX (ugly) I will have better than an STI performance vehicle and will be able to do it over a period of time. Yes I know its crazy to spend such money on an old car, but hey, its fun, I can keep my family and house and play with it over time.
Aero, will be something I give thought to but will be limited to the basics as I see it at present:
reduce air getting under the car in the first place
get rid of bonnet scoop (adding air under car) by using an intercooler at the front
reduce air getting under car after front wheels
extract air exiting under car smoothly
try and combine air smoothly from above car and under car without creating lift (ideally without a ridiculously big wing)
if any of these aero items can be made to create positive downforce then even better.
Thanks for your comments on my list, it is reassuring I am heading in the right direction with most of it.
Cheers
Greg Locock
The car will progress to be a track only car and I will look to get another commute vehicle but that will be a while off. Unfortunately I am like a lot of people = rich man's tastes/hobbies without the corresponding income!
Like all things there will be compromises.
1) You want the expensive race part to be in tip top order when you race, not half worn out.
2) Expensive race parts are mostly stronger than stock, but sometimes are not nearly as wear resistant.
3) If you crash or break your race car your daily driver is gone.
4) To keep your race car competitive, you will often have it of the road to perform lots of work. Once again, no transport if it is also your daily driver.
5) What do you drive when you go to pick parts for the race car.
6) You don't need a trailer and all the paraphernalia. You can do a deal with your local tilt tray car recovery operator. You can even drive your race car on the road occasionally and to and from meets, but if you break it you need a tilt bed at non negotiable rates.
1)it is our 2nd car (no 1 car is a subaru Liberty wagon) so doesn't see a lot of road kms
2)With subarus there is so much interchangability that most parts will just be late model STI parts (6 speed with DCCD, rear diff/axles, etc)
3) another impreza shell for $4k, get the mrs to drive me to work for a little while or get fit and start jogging/cycling
4)Most work should be able to be done in a weekend ( I have already done 6 speed conversion to a friends 92 subaru in 3/4 of a day) I aim to have all parts for a particular job before starting it.
5) see 1)
6)Local for us here in Australia is not that local and would cost several hundred dollars every meeting without a trailer.
3rd car in the family is then another cost but will come later.
Also you miss a big factor here, I look forward to my drive to and from work at the moment which if it were just a commuter this would be lost. Whatever car I drive I like it to be enjoyable. (even the No 1 family car is a 3.0 H6, 6 speed manual!)
I guess it comes down partly to most of motorsport on a club level doesn't make any financial sense, yes some things are smarter ways but overall there is some personal preferences in it all.
How hard and expensive was the 6 speed conversion for the H6.
I have considered a H6, but I occasionally tow a heavy trailer with a veteran car in it and automatics always blow up shortly after. A blown manual transmission clutch is a much more palatable failure if you have to have a failure.
The Subaru Liberty H6 seems very good value here in Sydney at the moment.
I can do most things, but I hve no first hand experience with Subaru and what fits with wha, and what are the good parts and what breaks and what is bolt in and forget with them.
The Liberty H6 is the 3.0 RB which is a factory 6 speed.
The conversion was done to a 92 RS liberty that has a STI 2.5L engine.
The conversion would be similar with the H6, just need the right assortment of parts and everything basically bolts in.
For the towing auto consider a good (no just the OE option) transmission cooler. I would recommend the 2.5L turbo engines for a good tow vehicle, plenty of torque!!
the 6 speed is a very strong and reliable unit, larger clutch than the 5 speeds also
See here for good info on subarus
http://www.rslibertyclub.org/forums/
http://www.ozliberty.com/
The liberty H6 has an impressive legal tow capacity also at 1800kg for a braked trailer!
Pat, do I know your name from Australia F3 or am I thinking of another Pat??
I am on the central coast so tracks are a little further for me (wakefield park is a trip! EC is easier!).
