UG Pattern Questions
Software Re: NX2 or NX4
Constraints: Parametric model
I am trying to figure out how to create a pattern (diamond) of cylinders on a cylidrical surface.  I would idealy like the cylinders normal to the surface, but that isn't a must have.
Question 1:  What is the easiest way in UG to do this?
Question 2:  Does UG (or will) UG have a feature similar to the "fill pattern" command in ProE WF2?
I appreciate the help.
-Paul
RE: UG Pattern Questions
In drafting there is a Area Fill which will fill an area with a drafting pattern for thing like wood, liquids, earth, etc.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
