Pipe radial expansion due to internal pressure
I would like to calculate the increases in internal diameter and external diameter in a pipe full of water when the pipe is pressurized.
Could anybody provide the formulas or advise where I can find them?
The ratio R/t is 8.625.
RE: Pipe radial expansion due to internal pressure
With r/t>5 Hoop stress can be taken as pressure*radius/thickness
If the pipe is out-of-round, it will tend to round up when pressurized.
If your pipe wall is more than 1/10 of the radius which I suspect it is then you need to use Thick Walled Cylinder Theory see page 6 of this link titled "Constitutive Equations".
regards
desertfox
here's the link:-
http://ww
