Batch Printing
Batch Printing
I'm trying to set up some batch printing where I work. We can't use a pdm system because of multiple locations...among other issues.
We've just moved to one .slddrw file per .sldasm or .sldprt. I'm looking for a program that I can store lists for products. We reuse parts in many different products. I want to be able to store lists to cut down on errors, where not all the parts used in an assembly/product are printed. I've used swBatchPrint v1.4 but it only displays 8 characters and has issues with spaces, this won't work.
Does anyone know of a program that will allow me to setup print lists of SW drawings that can be edited if need be?
RE: Batch Printing
http://swtools.cad.de/us_prog_pac.htm
RE: Batch Printing
RE: Batch Printing
-Dustin
Professional Engineer
Certified SolidWorks Professional
RE: Batch Printing
bmrao123-Is SW scheduler built into PDMworks? The way our multiple locations are setup a PDM system won't work.
sorg-This program looks like what I'm looking for. I'll give it a shot.
RE: Batch Printing
Have you guys looked at PDMWorks enterprise? It is supposed to allow for multiple locations. I think it is one vault that is replicated but can be set so all the replicated sites update themselves at night. It may also check as files are checked in and out and do individul files as needed. Not that it will solve your printing issue but something to consider for better file management.
RE: Batch Printing
Eric
RE: Batch Printing
Of course you could pack and go each assembly to a clean directory then run the print drawings macro to print drawings from that dirctory. Then just delete the folder to avoid having 2 copies.
Had i understood pack and go that is what i would have used rather than writing the macro, but the education was nice.
RE: Batch Printing
I was using the assemblybom macro to give me a list of all the parts of an assembly. I then took this list and imported that into excel and searched the network for all the copies of the files. This gave me a list of all the parts of the assemblies (library parts as well)
In some instances there were 3 or 4 files with the same name in other assemblies folder. I then was able to delete files with the same name but different extensions or library parts(pdf,dxf) then i sorted them and printed out the entire list.
The search function also gave me the file locations so if need be i could search and destroy duplicates also save this off later to print all needed files.
After reading your oroginal post i relaize that pack and go may be the solution.
