General table auto sizing issue.
Hello all, I am having a problem with a general table that I have set up in a drawing template. The table has many merged cells and custom properties within it. When I go to tools/options and make a change on something or even if I don't make a change and just click ok it will expand the columns half way across the sheet. When it does this I have to manually adjust the column width in each column via right click/formatting/column width. Does anyone know what could be causing this or if there is a way to lock the size of the table? Any input would be much appreciated.
Joe
Joe
RE: General table auto sizing issue.
Any body has any simpler method?
Here is an Option to reset the rows height of a SW base table to fit the font size using the following macro from:
http://3dawn.com/Free%20Solidworks%20Macros.html
Macro name " Reset Table Row Height "
Nothing About a macro to automatically adjust the size of the columns.
