Meshing an orphan part
Hi all,
I have 29 orphan parts that I've imported from Mimics (.inp files).  I'd like to know how to mesh these parts using the Mesh module.  When I try to use 'Mesh -> Part'  it says an orphan part can only be modified with the 'Edit Mesh Toolkit'.  Any advice is appreciated.
Max
RE: Meshing an orphan part
Abaqus does not allow me to create Independent instances on the orphan meshes I've imported.  So I have 29 Dependent instances.  It says in the user manual I should be able to mesh the Dependent instances; however, when I do try to abaqus returns 'Dependent part instances cannot be edited or assigned mesh attributes'.
Anyone know a way around this?
Max
An orphan part is just a mesh, i.e. a collection of nodes and elements. Only the geometric parts can be meshed.
Is it possible to extract/convert to 3D geometry from an orhpan mesh? How do I proceed with the analysis if I cannot mesh an orphan part?
Max
I am still very new to this program so I don't know if this will work but could you use "Part2DGeomFrom2DMesh" to convert the mesh to a new part?
Dan
