Dutch Rules for Pressure Vessels (Stoomwezen)
I am looking for spreadsheets or software to calculate pressure vessels according the dutch stoomwezen rule.
RE: Dutch Rules for Pressure Vessels (Stoomwezen)
There is a software for design of items under pressure, flanges and heat exchangers,approved or endorsed by Stoomwezen.
Name of softwere is: SCADES.
Supplier is CEA ,
location is in CAPELLE AAN DE IJSSEL near Rotterdam city.
CEA is also representing COADE in the Netherlands
(COADE = is the owner of pipe stress software CAESAR II).
Note: CAESAR ( has also an option for Stoomwezen).
Fathi
Vessel / stress engineer
The Netherlands
When you are designing pressure vessels for use in Europe you now have to comply with the Pressure Equipment Directive (unless you manage to install it before the 29th May 2002).
The directive has very specific requirements regarding risk assessment and you can obtain acopy from http://ped.eurodyn.net
This directive removes all national requirements from member states and all restrictions to trade as long as the requirements of the directive are met.
No one member state can insist that you use a specific design code so you could use ASME VIII Div.1 (USA), PD5500 (UK), AD-Merkblatter (Germany) or Stoomwezen (Netherlands).
There are one or two problems at the moment. Although you don't have to use AD-Merkblatter in Germany the new set of codes are not valid until 29th May and so, if you do use this code before this date outside of Germany you still need 3.1c material certificates. The German system is also being attacked at present becuase they are adding new restrictions to trade. They are setting different mandatory inspection intervals for AD-Merkblatter and other codes, making it uneconomical to use any other code. We presume that they will be taken to the European Courts in the not to distant future.
Fawkes
