Hydrotest Pressure of P.V.
Hi All,
when designing a P.V. through compress,the (shop)Hydrotest Pressure should be 1.3 times MAWP or MAP or DP?
appreciate your help
RE: Hydrotest Pressure of P.V.
ASME says 1.3 X mawp Which could be design pressure if no calcs are done to establish MAWP
Come user specs say 1.3 X map and UG-99(c) allows for that.
So you have some reading to do and decisions to make.
"Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
Tom Barsh
Codeware Technical Support
www.codeware.com
