R18 Help Docs
R18 Help Docs
R18 Help Docs
For some reason when I try to associate R18 with hitting F1 it will not work. The only way I am able to get the Docs to work is to create a shortcut on the desktop.
I have updated my Java and tried to fix this numerous times. Has anyone else had this issue?
RE: R18 Help Docs
Slaen,  Your doc level must match the SP level.  You should have received Help Doc CDs at the same SP level.
Derek
RE: R18 Help Docs
Dear Slaen,
Dassault is aware of this problem and the only way around it is by going into Environment editor and creating a new user and setting the environment from Global to user. You will have a separate icon made on your desktop to access Catia. I hope this helps.
