Rapid cooling of 45 carbon forgings
I'm going to show some ignorance here.
We use some 0.45% carbon components machined from forgings. Normally the forgings are slowly cooled, even annealed following forging. If the forgings were allowed to cool to, say, 350 deg C then quenched to speed up cooling how would this affect the hardness of the forgings?
It's being suggested that by doing this there would be a saving in forging costs and with modern machining tools there would not be any increase in machining costs.
Normally I might try some practical trials, but this is not possible at the present moment.
Any comments?
Any comments?
RE: Rapid cooling of 45 carbon forgings
With a plain carbon steel, with little or no alloying elements, most of the transformation will be complete by the time it gets to 350 C. With a higher alloyed steel, maybe not.
Even at 350 C, however, quenching can lock in some residual stresses that could interfere with the machining, either by moving during the machining or by distorting the part (up to causing cracking of the material) after machining.
It is quite possible that everything would be fine, but without knowing more details, it could as easily cause a lot of problems.
rp
The steel, just a plain carbon steel eg C45, 080A42 etc.
The cooling rate no idea, say off the hammer, onto a mesh belt conveyor with a variable speed drive, then off the end into a quench tank. (I'm just guessing here, not sure what they have in mind)
We're not talking about high precision machining, tolerances say +- 0.003".
Is there any data around on resulting hardness after quenching from these sorts of temperatures? Or am I looking to do practical tests myself? (which I would like to do but currently can't).
Rather than install a quench system that you have to maintain, why not install a series of large fans to speed up cooling? You could start forced air cooling at a higher temperature, say 425C, which should not produce the acicular structure that machines don't like.
Depending on the geometry of the forging and the geometry of the machining operations, this could be considered fairly tight. But, there are chances with everything. Being a plain carbon steel, and assuming a failry uniform geometry (and L/D ratios of less than 3), you are probably going to be OK. For long, slender parts, the water cooling from 350 C (660 F) is likely to bow them, and unless stress relieved, will bow more when machined (even if straightened).
rp
So, could the forgings be cooled from the hammer to give Rc30/35 and so reduce forging costs due to quicker cooling?
Or is someone spinning me a line....
That is, it is not cooling the forgings more quickly that provides the cost savings, but not requiring a slow cool permits the parts to be processed on equipment that can process them more economically (specifically, equipment that does not have provisions for slow cooling to ambient). Quenching them off the forge would not save any money and there are several metallurgical reasons it would not be beneficial.
With C45, if the machining is done with tool steel machining tools, the lower hardness greatly increases tool life; the lower the better. However, with carbide machining tools, tool life is unaffected up to around 35 HRC or so. What I'm saying is that in the past, the slow cooling may have been economically justified because of the lower machining costs. If the machining is now done with carbide tools, the economics may change.
rp
Did you say the final hardness required?
the configuration & hardness will dictate machining sequence.
This may be over kill but I like to Normalize , Harden &
Temper for forgings after rough machining.
#1) to remove residual stress from forging.
#2) at 30-35 HRc is easier/better for machining
material dead soft is not condusive for
machining. it tears and has a bad finish.
Chocolates,men,coffee: are somethings liked better rich!!
(noticed in a coffee shop)
1) The part is a forging
2) The material is a 0.4-0.45 % carbon steel
3) I can get the forging machined at Rc30-35
4) I can use the final part at Rc30-35
So if I understand correctly -
a) from the hammer, load the forging onto some conveyor
b) the conveyor is fitted with fans to provide an air blast to cool the forging
c) the rate of cooling is controlled and determines the hardness of the forging
d) it is possible to achieve a final hardness of Rc30-35 by this process.
As a result there would be cost savings from -
i) no additional annealing after cooling from forging
ii) no additional heat treatment after machining to increase the hardness/strength to the required level
I presume the initially there would need to be some experimentation with the cooling conveyor to achieve the RC30-35 hardness, and machining trials to check any resultant distortion??
Please fee free to correct any misinterpretation's of the comments made.
And thanks to all who have contributed to the discussion (and my education)
I suspect the air cooled hardness will be on the low side if not below the 30-35 HRC range. Unalloyed .45%C steel may reach the mid 20's HRC, and you should be able to skip additional annealing.
If your application still needs the refined structure that the annealing provided, in the future you may want to consider a microalloyed 1045 material that you can cool directly from the press without additional heat treatment.
You seem to have changed your question and I am no longer sure what you are asking. If your original process required a heat treatment after machining, I doubt you will be able to eliminate that with this material.
rp
Lets face it, times is hard! This started off following up comments on chopping down costs after the forging hammer. Clearly, if the forgings can be service ready from the hammer, there are furthers savings.
I suspect there is no real future in this.
Just buy cheap forgings from China, then a bit later get the Chinese to machine them cheaply as well.
Hence air cooling was proposed,which might result in hardness of 20-24RC. Probability of residual stress is reduced and machinability is good.
