Slurry coating question
Is there any reason why using a slurry coating as a solid mold, like a plaster mold in a vacuum flask, won't work?
I have a casting process that currently uses a vacuum flask, and a plaster to cast non-ferrous alloys. Due to the superheat and reactivity of my copper casts, it has become a real pain to cast the copper parts.
I was hoping to find some kind of alternative but it is proving very difficult. I like the properties of the slurry coats that I have found online, but am disappointed by their limited (to me) application. But why think inside the box?
Expense is no real problem, if I can get this process to work...
RE: Slurry coating question
Excessive thickness of some ceramics as they dry/cure will cause them to crack.  Investment-casting slurry is applied in thin coats to help prevent them from cracking, or at least so I've been told.
ah so.
this is definitely an issue... conquerable? perhaps...
 I am going to probe a little deeper some of the companies I have been chatting with...
Are you talking about something like sandcasting?
like sandcasting in that the flask is loaded with mold material? yes
Yes.  Pre-heat, cooling rate, thermal-shock, number of dip-coats, kaowool, all carefully controlled.  Why using flasks?  Casting weight?  Highly-automated?
"Due to the superheat and reactivity of my copper casts, it has become a real pain to cast the copper parts."
How?  Why?
