Converting (s)cfm to lb/hr for steam?
Hi, I'm wondering about converting cfm of steam at a certain pressure into lb/hr
In this case I'm working with 8-10 cfm of steam at 45 psig, am I able to convert that to lb/hr or do I need more information?
Thanks!
Thanks!
RE: Converting (s)cfm to lb/hr for steam?
cfm= volumetric flow rate
lb/hr= mass flow rate
Sounds like a h/w problem though so I will let you find the formula's for the flow rates in ANY elementary text or google.
