Raft VS Piles
Raft VS Piles
Raft VS Piles
I looked at some trial holes for a house (2 storey). The ground make-up was generally loose sand (3ft) over soft blue cobbly clay (10") over running sand.
I am assuming a raft foundation would suit this situation, are there any specific issues relating to the ground conditions I should be looking at?
What would be a practical bearing pressure to assume for this type of ground. I think the house will impose a pressure of approx. 20kN/m2.
If I build up existing foundation excavations with hardcore compacted in layers to the underside of the raft would this be reasonable?
RE: Raft VS Piles
Perhaps a call to your local geotech firm would be a good start.  It sounds like a fairly nasty subsurface set up.
