Multiple detail views
Is it possible to create multiple instances of the same detail view in the same drawing.  I have created a detail view to dimension some features, but the view has got crowded, therefore I would like to duplicate the detail view to dimension the remaining features.  I know that if you copy and paste the detail view from Part Navigator, it creates a new detail view but with a different letter.
RE: Multiple detail views
For lack of a better approach, you can turn off the view label by double clicking on the label, then add a manual label
Create a new sheet with the same area detailed?
I think turning off the label is a good aproach as it keeps everything on one sheet.
Thanks for the input.
Would increasing the scale of your view help?  If it's at 1/1 scale, increase it to 2/1.  That will spread it out a little.
Al
