Top Down Context Re-Attachment
I have a top down assembly that became corrupt so I had to go to the back-up file from the day before.  There is a part that was created in-context after the save date of the assembly that I would like to use (not have to re-create).  The parts' shape is determined by other parts in the assembly.  Is there a way to insert the part and re-attach those relationships?
RE: Top Down Context Re-Attachment
Bring the part into the assembly. Edit the part within the assembly and edit the pertinent sketch(es). Using your 'Display/Delete Relations', delete the existing external references, then redo them. You could also select each reference, without deleting it (in the Display/Delete window) and try redefining it in the context of the new assembly.
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
What about the mates?  Just let it float and define the sketches?
If you have replaced the corrupt file with the back-up copy (same name, same location) you should be able to just insert the missing in-context file. Once re-positioned (using regular mates) the geometry should reassociate itself.
cheers
The part is newer than the assembly.
As long as the parts that were referenced by the in-context part are in the assy, that shouldn't matter.
cheers
