Air Cooler Inside the Building
Hello Folks,
I want kindly ask you if you ever came across ACHE which was installed inside the building.
Do we need to design a HVAC system so the coolers can perform during Summer time?
Any comment is highly appreciated.
Frank
RE: Air Cooler Inside the Building
Frank,
To properly function, ACHE needs to reject the heated air back to atmosphere or be used in some other process without being recirculated back to inlet side of ACHE.
Yes, i know of some ACHE that are installed within a building, but the rejected or waste heat is rejected outdoors and not circulated.
hope this helps . . .
good luck!
-pmover
