BLDC: Coil Windings and their effect on maximum RPM
I understand that there's a direct connection between the number of windings on each pole and the maximum RPM the BLDC can achieve. I understand that torque is proportional to the current in the windings and since less windings usually enables enlarging the winding wire thus enabling more current can enter the motor. Consequently enabling the motor to reach higher acceleration. But what about the correlation between the number of windings and the created magneto motive force F_mmf=N i
is that parameter only pertinent to the induced emf or is it just that only after certain point the number winding of provide better RPM - so called the turning point
Appreciate all who can help
RE: BLDC: Coil Windings and their effect on maximum RPM
F = B x l x I
V = B x l x v
If you reduce the length of the wire (number of turns), the force per unit current goes down as does the voltage per unit velocity.
Electrically, the maximum motor speed is determined when the motor BEMF equals the supply voltage.
By changing the number of turns you will be changing the induction of the windings. With AC and pulsed DC the inductive reactance is more important than resistance in limiting the current.
Bill
"Why not the best?"
Jimmy Carter
two more related questions
sreid
Isn't the figure for maximum acheivable torque also dictating some speed limits?
Bill
about magnetic saturation
Why and how does magnetic saturation happens?
thanx
Saturation limits the maximum lines of force in a magnetic material.
Bill
"Why not the best?"
Jimmy Carter
From the first relevant page in a Kollmorgen catalog I yanked off my shelf:
Winding A has a resistance of 1.12 ohms and an inductance of 1.7 mH. This provides a torque constant Kt of 0.157 N-m/amp and a back EMF constant Ke of 16.4 V/krpm. Continuous current is rated at 6.14 amps.
Winding B has a resistance of 7.06 ohms and an inductance of 10 mH. This provides a torque constant Kt of 0.391 N-m/amp and a back EMF constant Ke of 41.0 V/krpm. Continuous current is rated at 2.46 amps.
What's the difference? Winding B has more turns (2.5x) of narrower wire with the same "fill". Resistance and inductance increase with the square of the number of turns, so are over 6x greater (but note that the L/R time constant remains constant). Kt and Ke both increase linearly with the number of turns. Of course, with a higher Ke and a given supply voltage, your top speed is lower. The net effect compared to winding A is essentially the same as adding a mechanical gear reducer of factor 2.5 to the output shaft.
Of course, if you kept increasing the number of turns, you could drive the iron into magnetic saturation (which occurs when virtually all of the micro magnetic domains in the iron are already aligned, and adding extra external field from more current has little to no effect), but most motor designs of this type are capable of taking a variety of useful windings before getting significant magnetic saturation.
Curt Wilson
Delta Tau Data Systems
I have some additional questions and I would appreciate your help very much.
In this discussion we talked about the effects of adding windings and the pros and the cons of it. If extra windings hurdle the maximum achieved speed why not automatically stick to as least windings as possible. I know that at this situation the speed achieved per volt will be the maximum. Other than that I know that the wire will be thicker thus I will be able to drive more current into the motor which will help me with more torque. Wouldn't it be best speed wise and torque wise. Or will the torque be hurdled and for better torque more windings is preferable
Note that the Ke back-EMF constant and the Kt torque constant vary together. If you cut one in half, then you cut the other in half as well. In consistent units (SI, with Ke in V/(rad/sec) and Kt in N-m/A), they are the same numerically.
This is a consequence of the law of conservation of energy, or colloquially, "there's no such thing as a free lunch".
The motor torque equation is: T = Kt * I
The motor generator equation is E = Ke * w
By conservation of energy, electrical power must equal mechanical power: E * I = T * w
Substituting: Ke * w * I = Kt * I * w
Therefore: Ke = Kt
So if you reduced the number of wirings, you would reduce the torque per unit current. So you need more current to get the same torque. Because heating is proportional to the square of current, even with reduced resistance, you will not be able to get more torque out.
Curt Wilson
and another one
The numerical equality between Ke and Kt is based on making no references to mechanical or electrical losses because usually there's some difference between them right?
And for the sake of semantics do most catalogs offer Ke and Kt with the field flux factor already included
(which in brushed dc engine is usually in the stator)
On the electrical side, the terminal voltage (let's use the simple case of a DC motor) can be expressed as:
V = Ke*w + R*I + L*di/dt
Of course, the R*I term represents a loss.
On the mechanical side, the shaft output torque is the generated torque minus losses (e.g. windage, friction).
So if you were just to measure electrical input and mechanical output and calculate as if the whole system were lossless, you would not derive identical values for Ke and Kt.
The values of Ke and Kt are dependent on the magnitude of the field as well -- in the absence of magnetic saturation, directly proportional to this field strength.
Curt Wilson
Looking on a BLDC motor catalog for motors with the same iron I've noticed different motor windings but similar power ratings.
Since you have a thicker wire more current will be drawn from the power supply. Although the current goes up the voltage which is dictated by the power source stays the same. I understand that in such a case it necessarily means that I have to deliberately restrict the voltage to prevent over heating.
If my system can't reach the nominal power output in anycase how do I know if its problem isn't with the voltage? Meaning that having the ability to draw more current can help me.
Do I increase the wire length 3.44 times or will there be more to it since I won't be changing the wire diameter like in the example with Hyboxis? Is the change in inductance the only significant factor in determing the N-m/A to RPM/V ratio during a rewind (assuming no magnetic oversaturation)?
The problem with trying to increase the wire length by 3.44 times without changing the wire gauge is you'll run out of space in the slots.
If you do increase the length Nm/A should increase by about the same factor assuming no magnetic saturation.
If I increase wire length 3.44 times, decrease current draw by only 50%, keep wire diameter the same.... does that mean it dissipates(3.44 / 2)^2 (2.96)times more heat from the current through windings?
What effect does increasing the diameter of the rotor have on N-m/A vs RPM/V? Is it linear with diameter, or perhaps linear with circumfrence?
At 50% current the I^R losses will be 50%^2 or 25%.
Increasing the wire length and holding the current constant will increase the losses proportionally. A 3.44 increase in length will cause a 3.44 increase in losses at the same current.
50% current and 3.44 times more wire length will result in 3.44/4 or 86% of the base losses.
Bill
"Why not the best?"
Jimmy Carter
