NX5; PMI surface finish max/min not avail for ANSI std
Using the 3D PMI module, ASME Y14.5M-1994 standard, ANSI surface finish symbols, the option is not present to utilize maximum/minimum roughness range, even though this should be an option (ie per ASME Y14.36M).
Is there a way to do this that I'm not aware of, or is this known, desired behavior?
Thanks.
Thanks.
