Infiltration Testing Techniques
In my area, I have been seeing a lot of infiltration-based stormwater management systems being put on site plans lately. I am curious to hear thoughts on A) the role of geotechnical engineers in the design of infiltration-based systems and B) what do you think are acceptable methods of determing design infiltration rates of native soils?
I have been looking at various state stormwater regulations and am pretty amazed at the differences in requirements for infiltration testing. On one end of the spectrum, I have seen allowances for percolation tests, default values based on USDA classification, and determination based on gradation analysis. On the other end, I have seen requirements for double ring infiltrometer testing at the base of the systems. Anyone have any experience with these various testing devices/procedures: constant head permeameters (aka "Amoozemeter"); Guelph permeameters; or Turf-Tec's portable, small-diameter infiltrometer?
RE: Infiltration Testing Techniques
The infiltration rates can be much higher than the recommend rates thought so it may pay to get a double ring done if it may reduce the size of your system significantly. Around here a double ring costs around $1500 per test and you can't do the test until excavation has been done to the final grade of the pond or infiltration structure. For those reasons I haven't see a lot of double ring tests done.
When I design infiltration practices, I generally like to get at least two borings in the infiltration area, usually the owner will only pay for one, but you take what you can get. Then based on the boring logs and soil type at the proposed elevation of the infiltration practice use the recommended infiltration rates. The recommended rates are generally pretty conservative and we've yet to have a system that doesn't draw down in the design period.
Its also good to have a geotech onsite during the installation of the system so they can make sure that what the borings say is there is actually there. If the soil type differ significantly overexcavation, gravel drains, or total redesign of the system might be needed to acount for the actual soil conditions.
The states that we work in allow for default design values based on USDA classification and I'm pretty sure that is how most of the systems are designed.
I understand that if there's a rock ledge three feet bgs you may not like the full-scale results. But, assuming you have some idea of what the subsurface looks like, wouldn't that be enough?
The only time I see SDRI's being used is for landfill liners where the client can afford them.
BigH that sounds like a good idea. However I've never heard of that being done before, but then again I'm pretty young. Most of the borings I get reports for are for 8-inch hollow stem augers, what kind of cost difference are we talking if you start casing the bore hole?
BigH, I don't think there is any reason why you couldn't perform falling head permeability testing during the initial site investigation to obtain a preliminary value. We do this frequently as part of the normal procedure for site investigations if the client knows the location of a retention pond, etc and sees the value in the small extra cost. However, if the testing is requested after the initial site investigation has been performed or the layout or grading change, the owner doesn't always want to pay to mobolize a drill rig again. Also, if a state allows a civil engineer to look at a boring log or test pit and use default design values, that seems to be the way that it is generally done.
Bpattengale, as far as cost diffrence goes between cased holes and augered holes, it all depends on soil type, depth of hole, and how your driller's rates work. In my area, augers and casing should both be part of the driller's standard equipment as either one may be needed on any given site. Generally speaking, if your driller is working on a day rate basis, casing a hole MAY not be any more expensive than using augers. In certain subsurface conditions, casing is the best, and sometimes only option. In my experience, if footage rates are used, casing will be more expensive than augers to drill the same footage. There are lots of other variables to consider. Falling head perms take time, so the drillers will have some down time.
My understanding of perc tests is that they have been proven to be suscptible to huge varitions even in very small changes in locations. My own experience with perc tests is that an engineer familiar with the local soil conditions can observe a test pit and estimate an infiltration rate more accurately then a perc test performed in the field. However, I know that different states have different perc test methods. The type of perc tests I am familiar with don't necessarily involve an excavator, but do require a post hole digger and a marked-up grade stake.
Maybe my situation is unique, but I have seen new proposed regulations pushing the field methods indicated in my orignial post. The double ring is particularly good for verification testing at the base of the system during construction. I imagine the redesign would be pretty tough to do at such a late stage, but I have seen the verification testing requirement written into some regulations.
Drill a SPT boring to a depth that extends at least 4 ft below the design base grade of the infiltration basin. Do a hydrometer test on one of the more restrictive samples and correlate to USDA texture classes (i.e., Texture Class I, II, III, or IV) with the appropriate perc rate for each class). Advance a second boring just below the infiltraion base grade. Install a 4 or 5-in diameter PVC pipe to that grade. Install a column of water and allow a 24 hour soak. After the 24 hour soak, provide a 2-ft high water column atop the bottom of the pipe and measure the infiltration rate for four consecutive hourly readings. Report the individual values and the average along with the soil boring logs and hydrometer/texture class data.
Here's the stupidity of this entire process. The design is based on the water column being infiltrated in a 48-hour period. The popular thought (not mine) is that if you have an infiltration rate of 60 minutes per inch a 48-in water column will infiltrate fully in 2 days. That's why in many areas you have to document that the water table is more than 4 ft below the base grade of the infiltraiton bottom. Well if you are just infiltrating water from a 4-in diameter pipe that may just be the case. It just won't work like that if you have a 20 ft by 40 ft "cell" that has a 4 ft separation from the water table. What matters most is the horizontal permeability. At some point you just can't just keep pushing water down and it has to flow away. This may be hard to explain in typing, but this is the big problem in my mind.
Hope this helps.
f-d
¡papá gordo ain't no madre flaca!
Like you, I would tend to think that there are going to be other factors at play in a full scale system that are not replicated by a 4" diamter pipe. So my question to you is this: in a perfect world with no cost limitations, what testing do you think would be most appropriate?
Infiltration tests are primarily governed by a vertical flow gradient of unity. Irrespective of the "soaking" period, the Fairfax method is really showing infiltration witn a vertical flow gradient of 1.0. There is no way that the horizontal flow will be governed by a gradient of 1.0! It'll be much less.
So, to make a long story short(er), I'd try to get some fix on horizontal permeability, some fix on the thickness of the most permeable horizontal layer and then consider whether you can move all the water that you collect horizontally away from the infiltration "pond".
There are mounding equations, well equations, etc. to help with this.
f-d
