Weld Repair
Weld Repair
Weld Repair
I am looking for advice on a weld repair.  The fabricator is fabricating a fracture critical steel girder with butt welds in the flanges.  During the inspection of one of the bottom flange butt welds, a slag inclusion was found.  The fabricator proposed a repair to remove the slag inclusion and re-weld.  The concept was proper and the repair was made and the weld tested again.  Now the repaired weld has a slag inclusion which the fabricator is proposing to repair by the same procedure, except being more careful.  Is it acceptable to remove and re-weld this splice again?
