Supporting Upper and Lower Bus in Stations
I am reviewing a 138kV station design with a upper and lower 3" alum. bus. Normally to connect the two bus together we use 2 split angle 2" bus in a "v" form. This design however has a single 3" vertical connection. My question is will this weaken the overall bus and cause concern for vibration or is there no difference structurally.
RE: Supporting Upper and Lower Bus in Stations
The attached file which is taken from the ABB switchgear manual gives some insight on the calculations required.
Marmite
