Patent Question : application of a device qualifies?
Note: did some forum searches to find the right one, didnt seem to be anything specific.
Looking for opinions. Lets not argue about costs, why do it, etc. Companies get patents for the IP, and so that even if they don't sue someone else over the violation, it keeps them from being sued by someone who does get the idea patented.
So we have an application, and now I've found an off the shelf ,albeit a very specialized, IC that can improve the general nature of the design. It does a specific function, that could also be done discretely or by a micro controller or DSP.
The product is targeted toward a specific user group, because if you look at it overall, it could be used in a wider venue, but thats not what the company targets.
So, from a patent perspective, I'm thinking that if they want to pursue it, its the specific function, not the fact it can use the special IC. But by generating the patent, it could preclude the competition from doing the same thing (in theory) by any method..special IC, DSP or discrete.
Just looking for comments and thought's before I approach the owner.
RE: Patent Question : application of a device qualifies?
If you use that IC in a non-obvious way (say, using an LCD controller to run a sprinkler system), then you have a basis for a patent. Targeted user group is irrelevant unless, again, the new use is non-obvious... using Segways as school child transportation is a given, but using the same base for keeping a non-mounted/hand-carried satellite dish pointed correctly during a wind storm may qualify (you heard it here first, so it's now public domain, no patents allowed
If I understand your question correctly, you are attempting to patent a basic idea, not necessarily the specific method with which it is accomplished. Typically those patents are more difficult to enforce as they are so generic. Specific patents are easy to break because all it takes is someone finding a different method of accomplishing only one of the main goals listed in the patent. You would simply write the patent in such a manner as to include all of the methods one skilled in the proper arts might use (i.e., ICs, processors), making sure to point out the "method" being patented is not the use of the IC or a processor, but the "algorithm" that it is implementing.
Dan - Owner
http://www.Hi-TecDesigns.com
> Non-obviousness
> Improvement over the prior art
see: http://
But, it ultimately depends on your actual patent examiner, some are more thorough than others.
TTFN
Much of that is dependent on the actual writeup of the application, if there's a sufficiently compelling argument toward the improvement over the prior art, which is essentially a marketing blurb, with technical backing.
TTFN
Think of it this way. You have a drink and a straw, and everyone that makes straws just makes...straws. However, you find a micropump that allows someone thats disabled...lets say no muscle control in the mouth that allows them to suck. You add the pump, and now they can drink.
They are still drinking thru the straw, just the nature of how the "stuff" is delivered to the user is new and different. Its not that pumps haven't been used before, and even to this application perhaps, but the fact that its directed to a specific segment of the population (the disabled)and improves the delivery method, makes it unique, no?
Oh...that was an example, but its in the public domain now
So what if this pump, is the easiest way to do it. Sure you could do it differently and maybe get the same results, but this is the sure fire way, and the pump is patented, so that if anyone else wanted to do it the same way...they would have to use this pump. Can you patent a product/design based on using a specific commercially available device, thus preventing anyone else from doing the same thing? I'm thinking thats pretty gray... and probably couldn't be patented using that as one of its basis.
TTFN
Prime example? Say you want to get fluids from point A to point B, so you use an impeller pump. But what if that fluid is bodily in nature and you can't have it mix with greases and the like? Someone comes along and creates a peristaltic pump, making all of the prior inventions outdated.
Dan - Owner
TTFN
Thanks everyone
