freezing an assembly drawing
I have a basic assembly that in assembly mode I can rotate a part of the assembly (using mechanism).  I have set this rotation so that it will always regenerate back to the same position (joint settings).
However, my question is, how do you go about freezing the drawing model so that if you had both the assy and drawign open, the drawing will not show how you have rotated the object, and will only show the regenerated view.
Many Thanks in advance.
