Using Excel Solver and VBA User Defined Functions
I would like to use Excel's Solver to minimize the sum of the square errors between observed data and a model.  I know how to do this if the model is an Excel function in cells in the worksheet.  However, I am working with a very complicated series of functions that I would like to be user-designed functions (UDF) written in VBA.  Is it possible to use Solver to optimize a cell in an Excel file that is a function of a VBA UDF?  I have attached a very simple model illustrating what I am trying to do, where "model" is a VBA UDF, and I would like to use Solver to minimize D9 by changing the parameters G4 and G5.
Thanks very much for any help you can provide.
RE: Using Excel Solver and VBA User Defined Functions
Yes, I have tried it using the file attached to my first post, but Solver returns the original input values, not the optimized values.  If anyone knows how I can get solver to work with a VBA UDF, I would really appreciate the help.  Thanks!
Thanks for your help, IRstuff.  Could you please further explain "You need to pass the parameters to the function"?  I realize that with the simple example that I have included that there are many ways to find the solution.  However, this is just a very simplified example of what I am trying to do.  The real function that I want to use is not linear.
Glad you've got it working.
However I think that your approach would be more "robust" if you set the Solver to minimise your target cell rather than trying to force it to zero.
That'll get rid of the error message, but Solver will still have the closest solution, even with the error message.
TTFN
