Anchor Bolt Detail Question
Having always used hooked anchor bolts, I am wondering if it is appropriate to use straight shank bolts for larger diameter bolts, 2" for example, considering that it may be difficult to bend the rods?
I haven't designed the embedded lengths considering the hook in the past but added them as an added safety consideration.
RE: Anchor Bolt Detail Question
Is the supplementary hardware necessary?
Most of the loads are generally shear.
I'm not convinced that having a mass of embedded horizontal steel (Ls) is not detrimental to the continuity of the pier,
so I guess a headed or nutted rod might be preferred to me.
I balk a little on the threaded base though because I am thinking of cutting oil not cleaned from the rod interfering with the bond.
Mike McCann
MMC Engineering
