mouse set up
mouse set up
mouse set up
Hello
I have set-up Pro/E WF3 on a sony laptop.  there is a logitech wireless mouse involved and I cannot seam to find where to set the buttons so I get functionality as expected.  the mouse is a VX NANO, any help would be apreciated.
RE: mouse set up
specifically I cannot get the spin to work on the middle button.
RE: mouse set up
Probably you have some mouse driver software that has set an alternative function to the middle button. I get this all the time with new machines. I would suggest either open the mouse panel from control panel and look for somewhere where you can change the button assignment. It should be set as 'middle click' to work properly. Alternatively look in the system tray area of the taskbar to see if you can access any mouse customisation faetures from there.
