Drawing Dimension at an angle
I am new to this and gone thru the tutorial and other documentation and no luck.
How can I give a dimension at an angle?
Is it possible to select a reference line before the first and second point for the dimension?
Any hot keys or settings?
RE: Drawing Dimension at an angle
The best way to do this is to dimension between an edge and a point instead of two points.  If you're stuck with points, add  a short construction line on the first point and constrain it to be perpendicular to your measurement direction.  Then dimension from it to the other point.
-handleman, CSWP (The new, easy test)
