Comparing of pipe thikness in ASME B31.3 and 31.1
In our piping spec for refinery is written
"As a minimum requirement, piping shall be designed in accordance with ASME B31.3, Process Piping. Steam, boiler feed-water and blow down piping, associated with steam generating equipment shall be designed in accordance with ASME B31.1"
I cheked the thickness calculation for above services (steam, blow down, ...) but they also calculated as per ASME B31.3.
My question is this:
1- Is it required the thickness for steam lines in refinery to be calculated as per ASME B31.3 or not?
2- What is the difference between thickness as per B31.1 and 31.3? which code has more safety factor? which thickness is bigger and why?
Thanks and Regards,
Thanks and Regards,
RE: Comparing of pipe thikness in ASME B31.3 and 31.1
You will get a more lively discussion
-MJC
The pipe used for Steam, boiler feed-water services normaly has a corrosion allowance of 0.125 while there are other services where is 0.0625.
These a pair of reasons of the diference
