high temperature bobbin
I'm looking for a thermoset or another material to do bobbin that will be functionning at about 300°C. Do you have an idea of what kind of material I can use for such an application?
I was looking on the Dupont website, but it seems that there is only 240°C UL material.
Thank you in advance for your help!
RE: high temperature bobbin
http://www.solvayadvancedpolymers.com/
Or look at www.matweb.com. There you can search for polymers by property including HDT.
There are also high temperature epoxies that can take that temperature.
There is not any memory with less satisfaction than the memory of some temptation we resisted.
- James Branch Cabell
In fact I'm trying to adapted the design of an existing product (Active magnetic Bearin) for high temperature use. So I'm looking for bobbins that coud support the wire. The resin has to be mechanically resistant to bear the wire, and the device muste be used during years at 300°C into ambiant atmosphere (no corrosive environnement / no pressure). The resin has to be insulating (because the magnetic steel which compose the electomagnet).
I will check for your recommandations, thank you for your help!
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
You are probably getting in the realms (i.e. 300C continuous)of where ceramics might be cheaper.
Rgds
