Translate Nastran to ANSYS - seamless?
Hi all.
This site is quite neat, although I'm not getting that much work done...
I'm living thru the nightmare of exporting a MCS Visual Nastran 4 Windows (Femap version 8) to ANSYS, preferebly version 6.0. My geometry seems fine, but I've gone from 184 Nastran property numbers (for a quarter model of a passenger railcar) to 7600 Real Constant numbers in ANSYS.
Any suggestions?
Any suggestions?
RE: Translate Nastran to ANSYS - seamless?
it's been a long time since I used the FEMAP translater but I do seem to recall this characteristic. If I remember right I had to colect all the similar reals and do an emodify to reduce the number of reals.......not a great answer but a solution non the less.
Good luck
do the import, then take the time to re-assign my element local axis directions in ANSYS.
GA
1. GXY still exporting to Ansys while in isotropic material condition, which Ansys reject it.
2. Non-Linear function is not equivalent (stress-strain) if weread again using ansys interactive (5.4 to 6.1).
3. FEMAP having trouble converting from Ansys PREP 5.7.1 to 6.1 because the digit on element indicidences ( i have known to solve it).
If you had ansys i recomended that you are using ansys interactive than other mesher like FEMAP, PATRAN, Altair. I have seen some, but Ansys is the best on meshing and the best answer for your problem. I recommended that you had IGES form.
FEM S2 Student: ABQ,NAS,COS,ANS,MAR,SAP,
STaaD,ETABS,GTSTRUDL, Civil Eng.
LOOKING FOR A JOB ....
David R. Dearth, P.E.
Applied Analysis & Technology
E-mail "AppliedAT@aol.com"
