Change a value of a selected dimension and rebuild
This seems really trival but I'm trying to change the value of a dimension that has been selected and rebuild the part.
Here is snap shot of the code where I prompt the user to select a dimension.  In the code I can retrieve the current value, but no I'm struggling with changing that value, then rebuilding the part.
    swApp.SendMsgToUser2 "Please select a dimension.", swMbWarning, swMbOk
    While SelMgr.GetSelectedObjectType3(1, 0) <> swSelDIMENSIONS
        Model.ClearSelection2 True   'Clear all selections
        While SelMgr.GetSelectedObjectCount < MINSELECTIONS
            DoEvents   'Wait for user selection
        Wend
        If SelMgr.GetSelectedObjectType3(1, 0) = swSelDIMENSIONS Then
            Set MyDim = SelMgr.GetSelectedObject6(1, 0)
        End If
    Wend
    MyDimValue = MyDim.GetDimension2(0).Value
Change dimension value here and rebuild part...
Thanks.
RE: Change a value of a selected dimension and rebuild
What is the context of what you are trying to do?  Part? drawing? assembly? Sketch?
-handleman, CSWP (The new, easy test)
It is a part file and I'm trying to change a dimension of a dimension that I selected that was a sketch dimension.
CODE
Option Explicit
Const MINSELECTIONS As Long = 1
Dim swApp As SldWorks.SldWorks
Dim Model As SldWorks.ModelDoc2
Dim myDispDim As SldWorks.DisplayDimension
Dim myDim As SldWorks.Dimension
Dim SelMgr As SldWorks.SelectionMgr
Dim myDimValue As Variant
Dim NewVal As Double
Sub main()
    Set swApp = Application.SldWorks
    Set Model = swApp.ActiveDoc
    Set SelMgr = Model.SelectionManager
    If Not ((SelMgr.GetSelectedObjectCount2(-1) = 1) And (SelMgr.GetSelectedObjectType3(1, -1) = swSelDIMENSIONS)) Then
    End If
    While SelMgr.GetSelectedObjectType3(1, -1) <> swSelDIMENSIONS
        Wend
    Wend
    Set myDispDim = SelMgr.GetSelectedObject6(1, -1)
    Set myDim = myDispDim.GetDimension2(0)
    myDimValue = myDim.GetValue3(swThisConfiguration, Empty)
    NewVal = CDbl(InputBox("Enter new value", "Change Dimension", myDimValue(0)))
    myDim.SetValue3 NewVal, swThisConfiguration, Empty
    Model.EditRebuild3
End Sub
