SW 2008 differences?
Hi all,
We just converted to 2008 this week and noted some changes(?)
1.Wwe frequently add sketches(text) and wrap to a surface, then change color of wrap to highlight. While it works on my system, it does not on a colleague's. The color option is grayed out.
2. I created a drawing and went to add a second sheet. I got a "cannot find format" message? The first sheet was good?
Any thoughts? Thanks
RE: SW 2008 differences?
2) It shows up fine on the first sheet because that was saved with your drawing template. If the sheetformat was saved out then the link to the format was lost and needs to be "reassociated".
RealView moved so it took a bit longer to find. Thanks for the tip.
