what file extentions should be cleaned from local directory
What file extnetions can be removed from the local directory on a Windows Based installation? Does anyone have a list of file extention discriptions that are gentrated from Ideas?
RE: what file extentions should be cleaned from local directory
The following is the file extensions I delete from My Usr directory
Please take a note I also delete CGM files and PFF files
Do not delete files while I-Deas is open
Also note anything with the the includes Ideas in the name will be deleted per the following list.
D:
CD \USR
DEL TEST10.CGM
DEL *.PFF
DEL *.CGM
DEL *.IPR
DEL *.LCK
DEL *.OPT
DEL *.OPR
DEL *.STAT
DEL *.APP
DEL *.AUX
DEL *.OUT
DEL IDEAS*
DEL .STOP*
DEL *.DAT
DEL STOP*
DEL EXEC*
CD \USR\SCRATCH
DEL *.SF*
DEL *.DSP
DEL *.APP
DEL IDEAS*
