Scripting Autocad from MathCAD using VBScript
Back again in the pursuit of drawing through mathcad.
Now I'm trying to draw from mathcad in Autocad using the scipted component. Are other people doing this? My VBScript skills are pretty limited and I'm stuck at trying to find the commands for VBScript which will create a line, circle, polyline etc. in Autocad. I'm also unsure of how that command will go.
If i have something like this:
Dim acadPLine
Dim x(6)
x(0)=1 'setting x and y coordinates for 3 pt polyline
x(1)=1
x(2)=5
x(3)=6
x(4)=8
x(5)=12
Set acadPLine = fdsafdjsklajfd;(x) -- not sure what to put after this equal sign.
Any hints? Also having a really hard time finding resources on the internet for using VBScript in Autocad. Are there books or sites with information?
Dim acadPLine
Dim x(6)
x(1)=1
x(2)=5
x(3)=6
x(4)=8
x(5)=12
RE: Scripting Autocad from MathCAD using VBScript
If you are using a recent version you can write a standalone version using VB.Net or you could try using VB for Applications in AutoCAD because versions 13 and 14 of mathcad are now xml based so you can interrogate the file to obtain the variable values.
The reason I was hoping to do it directly in Mathcad was because I would like to have the drawing update on the design sheet as I refresh the parameters. I could do it outside of mathcad and call the variables. Or just have mathcad export a simple script text file, but i would like to make the whole design process into one step that is easily reiterated if the original design is not adequate. Do you think this is not readily achievable? Programming is not my forte.
To me that seemed the easiest solution and, if you then change to another CAD or symbolic program you just have to rewrite one section.
