I (Current) Phasor and whether it is a compound number
I hope anyone can help me with this. When calculating voltage drops with a cos (Phi) lets say 0.8[**see note at hte bottom]. I am not sure whether I am supposed to calculate the voltage drop like
delta V = I (R cos (Phi) + X sin (Phi))
R being the real impedance and X being the reactive impedance
from what I understand it's agreed upon that "V" will always stay real while "I" can be complex.
does this mean that when I calculate the voltage drop on the reactive part I will write
delta V = I(R sin(Phi) + X cos(Phi))
[**]I hope that people understand this notation. I mean by it that it's the cos of the angle between the real P power(measured in watts) and the complex power S (measured in [VA]).
RE: I (Current) Phasor and whether it is a compound number
Z=(Rcos(phi)+ jXsin(phi))
Ohms law applies so V=IZ.
Don't forget this is in rectangular form. To get the same result as you would get from a multimeter you would need to convert to polar form.
Marmite
is an approximation of the difference in voltage magnitudes. In most cases the approximation is good. See the attached calculations.
I've encountered a few calculation from a course I took a few years ago where a voltage drop is calculated like this
the answer recieved was a scalar value of the this addition. although obviousely vector addition does allows it.
I thought they were refering to the fact that "I" is a vectorwhich is in an angle Phi to "V". And still it doesn't make too much sense mathematically. maybe they were refering to "V" in R.M.S value?
