Wildfire & appearance.dmt
Proe: Wildfire 3 M150
PDMLink: 8 M020
Desire: Load std appearance.dmt from pdmlink using pro_colormap_path option
I have enabled the pro_colormap_path (wtpub://pdmdd/Libraries/System/Config Files) where the appearance.dmt resides.  I also have a tree.cfg located in the same directory.
Upon loading proe the tree.cfg is being read, but the appearance.dmt is not.
Any thoughts?
Michael
RE: Wildfire & appearance.dmt
I don't know why it reads one, but not the other; however, PROE generally doesn't like spaces in file paths. My suggestion is to put an underscore between 'config files' and see what happens.
V
