Changing locked material thickness
I would like to change the material thickness on a sheet metal part. The problem is that as I go to Tools/Material table and then to the Gauge-area the material thickness option is shadowed out and I can´t change it.
Is there anyone who knows what might be locked as I don´t have permission to change the thickness. I even made a new copy of the part to exclude any write protection. I have been able to change the thickness this way on several other parts.
grateful for any help,
/Christer
/Christer
RE: Changing locked material thickness
Patrick
Good idea, however I do not have any part copy inside the model. Another model is linked to this one by a part copy but that could not possibly affect, can it?
Guess the simplest thing may be to re-build the model, it is not all that advanced.
/Christer
Check the variable table to find out.
If it's linked it will be indicated in the Formula column.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
