Numerical Integration
I am trying to figure out how to do numerical integration, using Simpson's Rule.  I could easily do it with Basic, but dang Vista won't run GW Basic.  I could also do it with about 1000 rows and then sum it up, but want to avoid that.
It is simply evaluate f(x)*constant, store it, recalculate f(x+dx)*constant, add that to 1st value, recalculate (f(x+dx+dx)*constant, add that, on and on till it reaches the upper limit.
Is there a way to do it using the automatic iteration feature (under Tools)?  It would be a sort of FOR TO type statement.  Goal Seek won't work, as I am just trying to sum up a lot of calculations, not find a root.
RE: Numerical Integration
It's easy to do with VBA in Excel.
Good luck,
Latexman
I'd just do it on the worksheet itself, as in http://oregonstate.edu/instruct/ch490/lessons/lesson11_files/CURVAREA.XLS
but if you are keen on Basic then VBA is worth learning.
http://www.mathhelpforum.com/math-help/computer-software/31305-excel-vba-simpsons-rule.html
or
http://www.mrexcel.com/forum/archive/index.php/t-99062.html
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Thanks, that is some good info.  Now, I have to learn VBA (sigh)
What does DOSBox have to do with this thread?
The integration as was mentioned can easily be performed in excel or vba.
electricpete
trashcanman complained that GWbasic doesn't run under Vista therefore looked for a spreadsheet alternative. Under DOSbox GWbasic probably may run in Vista.
You can get Visual Studio Express for C++ or Visual Basic for free from Microsoft.  The core of your GWBasic algorithm can probably be ported to VB Express with relatively minor mods.
TTFN
israelkk  - thanks. I understand now.
Hi there:
QuickBASIC runs under Vista -- QuickBASIC should take GWBASIC with no problem (just cut and paste)...
Gordan
http://engware.i-dentity.com
Hey Feric, you are correct, QB4.5 runs okay in Vista.  Thanks.  Now I can rock and roll.
