Datasheet question
Datasheet question
Datasheet question
While perusing through the technical specs for a SICK PLS I have on hand, I got stumped on the notation used for the maximum current (see attached)
Am I just reading into things, or is the value simply 600mA?
RE: Datasheet question
Poorly written.  Likely a switching supply that takes the current it needs plus some sort of quiescent current.
The key is the <= 17W.
At 24V;
17W/24V = 708mA
At 15V; (if it runs there)
17W/15V = 1.193A
etc.
Don't forget the added current for "external loads".
Keith Cress
Perfect. Thank you!
