Parametric splines in SE
Hi all,
I need some help on the following problem:
For a part with free form design, I would like to create parametric splines. This is, the splines are connected to points (e.g. ends of lines) that are constrained by dimensions. If I change those dimensions, the positions of the points are changed accordingly. I want the spline to follow these alterations in order to achieve a "parametric" spline. The problem is, as soon as I place a spline on the (parametric) points, I can no longer alter the dimensions of the points and end up with an error message from SE.
Any helps on this topic would be greatly appreciated!
Cheers,
Daniel
RE: Parametric splines in SE
For this I use the command Point in Sketch, and after I use the command curve for points in construction toolbars.
The command point are in Sketch->View->Toolbar->Change or modify toolbar.
Try the Curve by Excel table.  You can enter a list of keypoints to generate a 3d curve.
I have only done a handfull of splines and I would always use a protrusion.  I would like to know why you are trying to do the points method you described.  What are the advantages to this, or the dissadvantages to using the protrusion.
