archstyl & archtitl fonts
When using the abovementioned fonts, the autocad ways of writing degrees (%%d) or diameter (%%c) do not work. Any suggestions?
RE: archstyl & archtitl fonts
These are called Unicode characters and are defined in the font .shp file. Some custom fonts do not have these special codes. The easiest thing to do is use a different font like Standard or Romans.
