BOM error [i think]
BOM error [i think]
i am trying to change a few item numbers on the bom. usually,you can click on the box and it will ask it you wish to break the link to the part, and then you can select yes and change the number.
however, the problem im having now is that when i double click on the column, it thinks for a second, then just goes back to the regular mouse arrow, with no changes. all item numbers are doing this, and itis even happening on BOMs in other files.
any ideas? thanks
any ideas? thanks
